I am recursively looping through controls in my user control to enable/disable controls depending on security. I am wondering how I would be able to find any toolbars in my user control since it is not in the controls collection.
If you have a reference to the UltraToolbarsManager which defines the toolbars, you can loop through its Toolbars collection. Otherwise, while you are looping through controls, if you come to a control of type UltraToolbarsDockArea, you can access its ToolbarsManager property to get to the toolbars manager on the UserControl.
You can use reflection.
var controls = from f in control.GetType().GetFields(BindingFlags.NonPublic | BindingFlags.GetField | BindingFlags.Instance)
let c = f.GetValue(control) as Control
where c != null
select c;
foreach (c in controls)
c.Enabled = false;
