3555
maximize problems
 I am having an odd issue occur within 8.3.20083.2039.
I have an MDI application and I set it to maximize when form loads.  I have a ribbon on top. When I run the application it doesn't maximize all the way.  It is about 100 pixels off from the top.  If I hit restore and move the form closer to the top and hit maximize it works.
I just installed the Jan Hotfix to try and fix this but that did not work.  The problem is still happening.  Any suggestions?
