65
Problem With Column Order
In my code I am populating a grid from a datatable using SetDataBinding.  Then I want to loop through the grid and get the column order that I set in the grid designer.  However when I loop, I get the order that is in the datatable and not what I setup in the grid designer.  What am I doing wrong?
ugPenaltyTable.SetDataBinding(m_dsPenaltyMonitor.dtPenalty.DefaultView, "");
Infragistics.Win.UltraWinGrid.ColumnsCollection c = ugPenaltyTable.DisplayLayout.Bands[0].Columns;
foreach (UltraGridColumn column in c)
    if (column.Hidden == false)
         strData.Append(column.Header.Caption + "\t");
