If I have an UltraLabel with AutoSize=True and TextRenderingMode=GDI then the text is always wrapped. e.g. if the label text is 'Choose the closest region' then it is split over 4 lines with 1 word per line.
Changing either the TextRenderingMode to GDI+ (absolutely no chance I will do that), turning off AutoSize or changing WrapText to false (True is the default value) displays it on a single line.
This looks like it is a breaking change in the 2008.3 hotfix as my existing labels suddenly suffered this problem after installing it.
Martin.
Downloaded SR 2093 and this solves this. Thanks Mike!
I followed your steps, but nothing happens - the label stays the same size it was.
Do you have the latest service release?
I tried it in 9.2 but I have this problem:
And you will see that the heigth of the label is set to 70 pixels.
Very annoying if you have labels in a flowlayout like me ;-)
The issue I reported was fixed and is still ok in 9.2
Issue "16310: UltraLabel control is not working as expected with AutoSize to True" has been addressed in service release versions 8.3.20083.2066 CLR 2.0, 9.1.20091.2009 CLR 2.0.
rgds
I have the same problem (using 9.1).
You can see in the designer that the label immediately expands to 70 pixels.
Is this fixed already or have you found an other workaround?
