4133
Custom Formatting Of Read-Only Cell Text
I need to be able to show numeric values with a different number of decimal places on a per row basis.  I have two editor controls that I use in the InitializeRow event and this works fine for editing.  The problem is that I sometimes put the grid into read-only mode (cell = noactivation) and it appears that the editor controls do get set, but that they aren't used to display the data.  Is this correct?
I have read other posts that talk about DataFilters.  How would I use a DataFilter on a numeric column in the grid?  All the examples I have seen are for checkboxes.
Rich
Parents
No Data
Reply
  • 469350
    Suggested Answer
    No, that's not the case. The cell text is still drawn using the editor even when the cell is read-only. There's no reason why the Activation of a cell should affect the formatting of the text.
    If that's happening, it's a bug.
    It's the same principal. You would simply use a different type of editor, like an UltraTextEditor or UltraNumericEditor, depending on whether or not you want masking in the cell.
Children
No Data
