160
ValueBasedAppearance based on the value of another cell
I need some sample code on how to setup ValueBasedAppearance of a cell based on the value of another cell. The example in the Samples Explorer deals with value of the cell changing the appearance. Any help appreciated
Emil
  • 5
    If you add the UltraCalcManager to your form/app it will allow you to use a Formula Condition.
    You can then create a condition that references other cells.
    eg.
    ( [cella] > [cellb] )   if cella greater than cellb then true
    ( [cellb] <> dbnull() ) if cellb is not null then true
    etc.
    Hope that helps
    Zepp
