I have a tree which has 7 columns and viewstyle is in OutLookExpress Mode. The first column is enabled to show the expansion indicator. I have a requirement to show a dialogue on double click event over cell in 7th Column. After showing the dialogue box, it expands the node, which actually is not a requirement. So how can i restrict expanding the node on the double click event over a cell.
Thanks & regards,
Sriram Sarma.
Hi, thanks for the reply. My problem is resolved now. Basing on the column index, i am selecting the property of node expansion as None.
Sriram
The following code sample demonstrates how to use the UIElement.ElementFromPoint method to hit test for a particular element, in this case an UltraTreeNodeCellUIElement. Once you have a reference to the associated UltraTreeNodeColumn, you can decide whether to expand the node (set UltraTreeNode.Expanded to true) or "display a colorpalette":
private void ultraTree1_MouseDoubleClick(object sender, MouseEventArgs e){ UltraTree tree = sender as UltraTree; UIElement controlElement = tree.UIElement; UIElement elementAtPoint = controlElement != null ? controlElement.ElementFromPoint( e.Location ) : null;
UltraTreeNodeCellUIElement cellElement = null; while ( elementAtPoint != null ) { cellElement = elementAtPoint as UltraTreeNodeCellUIElement; if ( cellElement != null ) { UltraTreeNodeColumn column = cellElement.Column; UltraTreeNode node = cellElement.Node; }
elementAtPoint = elementAtPoint.Parent; }}
Hi Mike,
This property totally arrests the double click action on the node. But the requirement is when a parent node is double clicked which is in first column it should expand and the corresponding cell value in column 7 when double clicked should display a colorpalette. It means double click should behave in different way when clicked on firstcell and 7th cell for the same node (the tree is in outlook express mode).
Sriram.
Hi Sriram,
this.ultraTree1.Override.NodeDoubleClickAction = NodeDoubleClickAction.None;
