HiI have followed your Histogram tutorial to the letter...Working with Histogram Chart Data - Check HereI am using 2008.3 .net version and have even tried the 2008.3.2093 hot fixes but instead of looking like attachment "YOURS.JPG" it looks like "MINE.JPG"I seems the column width does not auto stretch across the x axis but the distribution curve is fine :¬(my project is attached too as "PROJECT.ZIP"i am using vs 2008 on a vista 64 box using netadvantage 2008.3 (also netadvantage 2008.3 with hotfixes)This problem gets even worse when you use large numbers as your datasource my project.zip shows this too.I have spent ages on this ... Any ideasThanksMr.Desparate :¬)
Thank you for all the info you have put my mind at rest :¬)
have a nice weekend :)
it won't be on our website because it was found internally and never reported by a customer. if you contact developer support about it, they enter a duplicate bug report for you, and at that point it becomes public and you can check the status on our website.
but i'm pretty sure this one is in the next hotfix release, which is being tested right now.
there will be a winforms 2009.1. it might seem a bit late, but that's only because we switched to a 2-release-per-year pattern for all platforms.
here's a recent blog post on 2009.1 winforms: http://blogs.infragistics.com/blogs/andrew_flick/archive/2009/03/25/netadvantage-for-win-client-2009-volume-1.aspx
Thanks David
I tried to get a report on this bug 15469 but saddly i can never get anything out of the support website search
Is there going to be a 2009.1 or is it the end of the line for windows forms support?im a bit confused so many different versions nowdays
Many thanks :¬)
this is a bug that was fixed recently. it should be released in the next hotfix.
the bug number is 15469. feel free to contact infragistics developer support (http://infragistics.com/gethelp) at any time to inquire about the status of this bug fix.
Project to go with above
