Hi All,
When i right click on a particular band header in an ultragrid ContextMenu should be visible,
on the other band headers it should not be visible.I have assigned keys to the bands during design time.
Am getting the UIElement where user has clicked on the grid from the following code
Point curPos = ultraGridSurvey.PointToClient(Cursor.Position);UIElement mouseUIElement = ultraGridSurvey.DisplayLayout.UIElement.ElementFromPoint(curPos);
At runtime how can i find out whether the user has clicked on a Particular Band or a Band Header.
Could any one of u help me on this.
Pavana
Hi Pavana,
Try something like this:
private void ultraGrid1_MouseUp(object sender, MouseEventArgs e) { // Get the grid. UltraGrid grid = sender as UltraGrid; // Get the element. We could use ElementFromPoint, but this is easier. UIElement element = grid.DisplayLayout.UIElement.LastElementEntered; // See if the element is already a HeaderUIElement HeaderUIElement headerElement = element as HeaderUIElement; // If it's not a HeaderUIElement, see if one of it's ancestors is. if (headerElement == null) { headerElement = element.GetAncestor(typeof(HeaderUIElement)) as HeaderUIElement; } // No HeaderUIElement found, exit. if (headerElement == null) return; // If there's a column, then this is a column header, not a band header, so exit. if (headerElement.Header.Column != null) return; // Found a band header. Debug.WriteLine(headerElement.Header.Band.Key, "Band Header Clicked"); }
