1401
How to hide particular nodes from WinTree?
I am using Binding List concept to create Node List and assigning this Node List to the DataSource of the WinTree as mentioned in the Post http://forums.infragistics.com/forums/t/5222.aspx
I am facing following issue:
1.     How can I hide the particular nodes from WinTree before assigning to the DataSource of the WinTree?
2.     Leaf nodes showing ‘+’ even though it doesn’t have Children.
3.      If I create WinTree object dynamically at runtime and bind the Node List to DataSource of it, ‘ExpandAll’ doesn’t work.
Thanks in advance.
Kumar
