305
Setting GroupByRow.Height Doesn't Work?
Does the UltraGrid allow you to set the GroupByRow.Height property via code?  I have ONE GroupByRow that I'd like to be as small as possible.
I have set the Override.RowSizing to Free and set the RowSizingArea to EntireRow for both the DisplayLayout and the Band.  I have also changed the MinRowHeight from -1 to 2 in both Override areas.
It allows me to set ugrd.Rows(1).Rows(0).Height = 2 just fine, however, I cannot set ugrd.Rows(2).Height = 2.  It ignores it.
Any help would be appreciated.
  • 18495
    Suggested Answer
    Hello Kyle,
    You can set the Height property of a group-by row in code, but the way the property is currently implemented, there are a number of factors that control the actual minimum height of the row.  You might be able to make the height of the row smaller by changing the font size (UltraGridRow.Appearance.FontData.SizeInPoints).
