I need to print more than one grid in the same page. I followed this post and it allows me to add two or more grids to a Report. One of the grids has the CardView = true and DisplayLayout.AllowCardPrinting = true.
Using the Report I can see that both grids are included in the same page, but the CardView mode is gone. If I use the UltraGrid.Print() method the CardView is printed fine. I can't use the Print() method because it creates one print job per grid. I need both grids in the same page.
Is there a way to include a grid set to CardView mode in a Report?
Also, I noticed the Caption is not included when printing, either on the Report or the Print() method. Is there a way to include the Caption when printing?
I'm attaching a sample project showing these problems.
Thanks.
Thanks for the answer Mike.
That's what I thought. I already submitted the feature request.
oscarmorasu said:Is there a way to include a grid set to CardView mode in a Report?
No, exporting to CardView is not supported. You should Submit a feature request to Infragistics.
oscarmorasu said:Also, I noticed the Caption is not included when printing, either on the Report or the Print() method. Is there a way to include the Caption when printing?
You could add anything you want to the report. So you could add some extra text or a header. There's a sample of this included with the WinGrid Samples Explorer. The samples install with the NetAdvantage SDK.
