1785
Merging columns
Hi... I have a WinGrid that is non-sortable and users can't move columns. I want to merge matching cells in the first two columns, but the second column should only be merged within the values of the first column.
For example,
NAME                   POLARIZATION    SUBLIST
Antenna One      VERTICAL              1
Antenna One      VERTICAL              2
Antenna One      VERTICAL              3
Antenna Two      VERTICAL              1
Antenna Two      VERTICAL              2
Antenna Three   HORIZONTAL        1
Antenna Three   HORIZONTAL        2
Antenna Three   HORIZONTAL        3
I want to display as:
                                                               2
                                                               3
                                                               2
                                                               2
                                                               3
Right now the VERTICAL for Antenna One and Antenna Two are also being merged.
Ideas?  Thanks...  Steve
