190
Default Sorting of Child Band
I think what I am trying to do should be simple but I can't seem to find the answer
I have an UltraWinGrid with two bands. I am using a BindingSource that uses a Binding List of one object type (Band 0)  that has a property that is a BindingList of a second object type(Band 1). I am able to sort the first band records by declaring the sorting rules in the Sort property of the binding source.
But I also need to sort the Band1 objects by a property of that object type. Can I do this in the Grid properties? What is the property I am looking for? This just needs to be a one-time sort. It won't change and the user cannot change the sorting via the UI.
I have looked at implementing a SortableBindingList extension but I just can't help but think there is an easier way to do this.
Can anyone help?
