The explorer bar has a context menu by default. One of the menu options is the ability to set the items to display in "Small images with text".
This is great, however which event can I use to know that this option has been actioned? Basically I want to know everytime the Group > Settings > Style has been changed.
Ryan
Thanks again Brian. That worked perfectly.
You can use the PropertyChanged event to get a notification when any property value changes.
Example:
using Infragistics.Shared;using Infragistics.Win;using Infragistics.Win.UltraWinExplorerBar;
this.explorerBar.PropertyChanged += new Infragistics.Win.PropertyChangedEventHandler(explorerBar_PropertyChanged);
void explorerBar_PropertyChanged(object sender, Infragistics.Win.PropertyChangedEventArgs e){ PropChangeInfo pci = e.ChangeInfo.FindTrigger( null ); if ( pci != null && pci.PropId is Infragistics.Win.UltraWinExplorerBar.PropertyIds && (Infragistics.Win.UltraWinExplorerBar.PropertyIds)pci.PropId == Infragistics.Win.UltraWinExplorerBar.PropertyIds.Style ) { bool stop = true; }
