When I view the wingrid on the feature selection, it works as I expect. When I select the down arrow, it goes to the next row. However at runtime, arrow down does nothing or if I am editing it goes to the next character. Is this a simple feature that I need to turn on/off or should I write a key press handler?
Thank you for the example. That worked for me!
HOWTO:UltraWinGrid Cursor Movement like Excel
