Hi this is a follow on thread from......... HERE
Although the histogram now works with your integer code tutorial if you use it in a real world program that uses floats 10000 -> 20000 it does not show the bars only the axis and distribution curve :¬(
I realy need Histogram to work properly. Is there a way to fast track this bug
I have attached a slight modified version of your integer tutorial that shows the problem
Nope it didnt make it...I couldn not have realy not enough time etc
I had to upgrade to 2009.1 sometime anyways :¬)
I just noticed 2009.1 is out ...I bet my bug missed the boatSomeone should realy look at the knowelge base it never shows any bugs after 2006
Thanks again I will have to contact support then
I recommend contacting developer support. They typically handle all such requests and should be able to set you up with a new build. Make sure you mention the bug number I gave you. You can get in touch with them here: http://infragistics.com/gethelp
Thank you all for finding and fixing the bug :¬)
I realy need to get this fix our data is always large numbers and cant start at zero :¬(
Is there a way i could get a new dll?
or when is the next hot fix due?
Many thanks again
This problem has been corrected. The bug number is 16397. You can use that number if you decide to inquire of its status with developer support. The fix will be included in the next available hotfix.
