Ellipsis displayed in my FormattedText style column. The column is set to display multi line text, Long text is wrapped into multi lines correctly, but when one word can't fit into the cell, ellipsis shows. Is there a way to wrap the word intead of showing ellipsis?
Crystal.
Hi Mike, I did that already. Thanks for looking into this.
Hi Crystal,
I'd have to see the bevahior to be sure, but that certainly seems like a bug to me.
I recommend that you create a small sample project that demonstrates this behavior and Submit an incident to Infragistics Developer Support
Hi Mike,
In formatted text cell, text within same word was cut off, words after were wrapped into next line. For regular cell, nothing was cut off, all text was wrapped.
Could you confim or have someone else confim that it's a defect? If it's a defect, do we need to submit a hotfix request?
The text does not wrap, even when CellMultiline is true? That sounds like a bug if that's what's happening.
You are right that TextTrimming was set in AppStyle by others. But without TextTrimming, words still cut off instead of wrapping into next line in FormattedText style column. Only ellipsis doesn't show.
I've submitted support request regarding to this issue. We'd like to have behavior for FormattedText style column and regular columns
