I'm having an issue with the Small Image screen not showing up when I try to attach an image to a button using your
UltraToolBarManager with the ribbon enabled. Seems the image form is not showing up whenever I try to set an image.
I then no longer have control with the VB.Net environment.
I can hit the ESC key twice and I then regain control.
Any thoughts? I do not see the screen behind any of the other programs running.
PR
Hello PR,
All of the supported environments are listed below: http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments.
Please do not hesitate to contact us if you need any additional assistance.
