When trying to use SaveAsXML on one form/grid in particular I am getting an error. I cannot reproduce the error on other forms/grids as it seems to work fine except for one form/grid. Any idea why I am having problems with only the one grid?
SerializationException was unhandled
Type 'System.Data.DataRow' in 'Assembly System.Data' version 2.0.0.0 ........ is not marked at serializable.
I am using UltraWinGrid v8.1
For some reason, the layout is trying to serialize a DataRow. The only way I can think of that this might happen is if you assigned a DataRow to the Tag property of some object in the grid - such as a column or band.
