As i was trying to do something , but didn't modify any code
but i'm getting following error
does not contain a definition for 'ultraGridReport_InitializeLayout'
how to fix it
The designer code (in the FormName.Designer.cs file) has a delegate to a handler procedure in your form page (FormName.cs) But that procedure is not there.
The easierst fix is to
1. open the form in the form designer (double click on the form in the solution explorer).
2. Highlight the grid control (UltraGridReport).
3. In the properties window, press the events button (at the top, looks like a lightning bolt)
4. look for the setting called "Initialize Layout". This will be set to the value "UltraGridReport_InitializeLaout".
5. Use backspace or delete to clear this setting.
Tthe problem should be fixed. You can double-click on the "Initalize layout:" setting if you need to add a handler for this event.
However, its possible that you won't be able to open the form in the designer. (Some errors prevent it from opening, I don't know if this one will).
In that case, you must open the designer code by right clicking on the designer code file (FormName.Designer.cs). and choosing "view code".
Then look through the code for a line that creates the delegate for "ultraGridReport_IntializeLayout"; I don't know exactly what the line will look like, but it will probalby use the += operator to add an object to an event and that object will probalby take the procedure ultraGridReport_InitializeLayout as a parameter. This is probably the only line that mentions ultraGridReport_InitializeLayout.
You need to delete that line. That will also fix the error.
