270
Columnchooserbutton problem when wrapheadertext is set
I have grid with columnchooser and have set wrapheadertext to true. So when I remove all columns from column chooser then the header collapse completely. So I cannot see even columnchooser button so that I can restore the column. I think this was because of the wrapheadertext property. It tried to wrap empty string (as there is no columns) and set height of the header accourdingly. So, it wasn't even displaying column chooser button. Is there a way to work around this problem?
Anil
