It looks like this feature is similiar to pivoting by a column (say date column) in a datatable.
My question is does anyone know how this works? I ask because I implement by own pivoting funcion, but my returned datatable cannot have the key in it of what is getting pivoted because it prevents the pivot.
i.e. I can't include DateID if I pivot by date
Primary ID DateId Date Country PopulationName
1 33 1/1/2007 US Population 1
2 33 1/1/2007 US Population 2
Since the grid is editable and users can change values I have to use the date column name to lookup the date id so I can pass that to the stored procedure to update the database.
Does the Row Grouping handle this automatically (a way to link date to Date ID and remember it) Or would I still need to drop the dateId field to properly pivot and have my own lookup table?
Ideally it would be nice to have the normalized datatable binded to the grid and then allow it to be pivoted while keep track of Id fields that are need for crud transactions. My entire application needs pivoting since I am dealing with timelines and users like to see those horizontal. This suks because the database is obviously normalized and not pivoted and I can't use VS out of the box datasets / table adapter manager. Dam users.
RowLayoutGroups allows you to use Groups (which the grid has always had) in RowLayout mode. It's basically just a way of providing group headers that contain columns or other groups.
I'm really not sure what you are trying to acheive, but it doesn't sound like RowLayout Groups would help you with a pivot grid.
In the 2009 release one of the new features was called Row Layout Groups. I was referring to that feature.
I'm afraid you lost me with your first sentence here. What feature are you referring to here?
It sounds like you are talking about OutlookGroupBy. OutlookGroupBy basically creates groupings based on cell values. So instead of a flat list of data, your data becomes a hierarchy with a set of GroupByRows at the root level and under each GroupByRow are the actual data rows that belong to that group.
You can group by any field you want and even have multiple levels of grouping. Beyond that, I'm not really clear on what you are trying to do here.
