I'm setting the value of a 1 byte Decimal field to the value of the Checkeditor.Checked property. I was expecting a True value to be a 1... instead, it's a -1 (negative one). Is that correct? I'm new to VB.Net, but in the VB like language I used in the past, True and 1 were synonomous.
When WinCheckEditor reads a Decimal value, it'll treat 0 as "false" and any other value as "true." When it updates the same Decimal value, it'll set the underlying value to 0 for "false" and -1 for "true". I believe that this might be something handled by the .NET Framework itself, rather than anything we explicitly implemented.
Whenever possible, I recommend that you use a Boolean value for your underlying data, rather than a Decimal, Double, Integer, String, or other type. That way, you avoid the need for the editor to perform these kinds of conversions.
