I'm getting the "System.FormatException:" when trying to edit cell value or set row filter on a datetime column
in your examples, and even in my test app.My Culture is RU
When i set FormatInfo to Invariant or "en-US" it works, but format of the displayed value becomes wrong.
ultraGrid1.DisplayLayout.Bands[0].Columns["RequestDate"].FormatInfo = System.Globalization.CultureInfo.InvariantCulture;
This is the same issue in the following forum thread:http://forums.infragistics.com/forums/t/24463.aspx
The announcement of the April 2009 hot fix (which is when we expect this issue addressed) is here:http://forums.infragistics.com/forums/t/24202.aspx
I'm experiencing the same problem. When is the hotfix expected?
Manuel
This is a known issue which has been addressed in the first hotfix; you should log an incident so that you receive a notification when the fix becomes available.
