220
How to Set X Axis & Y Axis Value
Sir,
  I have a dataset with 'N' columns. But i want to assign only one cloumn in X axis and One Column to Y axis. How to do it?  Does my Datasource assigned to Chart control should have only those columns  or it can contain many???
R.Vasanth
  • 26458
    There are different data requirements for different chart types. Columns can be excluded from the chart's datasource by using the following:
    chart.Data.IncludeColumn(numericColumnIndex, false)
    For the most common chart types (Column, Line) the first string column is automatically picked for the X axis or can be specified by RowLabelsColumn property. For Scatter charts, you can specify ColumnX and ColumnY columns explicitly.
    Alternatively, you can filter your data with a data view and use it as the chart's datasource.
