395
Checkbox in header on level 2 (in hierachical grid)
Hello guys,
I am using code from example on "
Knowledge Base Article: KB04883
HOWTO:How do I add a CheckBox to a WinGrid column header?
and able to add a checkbox into header. I also attached click event to that checkbox which un/checks all child rows.
The problem is when I try to use header checkbox in a hierachical grid, say level 2, the click event doesn't work properly. Once I click a checkbox in header on level 2, all checkboxes on level 2 are checked. It seems the header for certain level is one same object for all.
Any idea on this issue?
Elton
  • 469350
    Suggested Answer
    Hi Elton,
    The latest version of the grid (v9.1) has header checkboxes built-in, so you don't need to mess around with CreationFilters any more.
