In my winforms application I have the situation, that in some cases I receive multiple form activate events,
but no deactivate event. Sounds strange but I can reproduce the problem.
I have an MDI winforms application, which uses the TabbedMdiManager and the ToolbarManager.
The toolbar has several ButtonTools and one ControlContainertTool with a usercontrol. On form's
Activated/Deactivated event I show or hide some tools.
To reproduce the problem, I made a quick&dirty winapp which I have attached. Do the following steps to see
what's wrong:
Here's my output
Form_Index_2 deactivated...=====================================Form_Index_0 activated...Form_Index_0 deactivated...=====================================Form_Index_1 activated...Form_Index_1 deactivated...=====================================Form_Index_2 activated...Form_Index_2 deactivated...=====================================Form_Index_0 activated... // I didn't activate the first form!!Form_Index_1 activated...
Something is wrong now, because when I click on Tab "Form_Index_0", I will not receive an activate event. This causes that some tools are still visible but should not.
Is this a bug, or if not, how can I workaround this issue?
It would be great, if somebody could help me.
Thanks in advance,
