270
Comparing column values ?
I 've downloaded RowSummaryAverageWithNullcs sample project (article id : 10019)  from Infragistics website. I 've added a column in testdata function.
dtData.Columns.Add("Column 2", typeof(int));
In initializelayout event,
if i use // formula 1 line  as :
e.Layout.Bands[0].Summaries["Summary"].Formula = "sum(if(isblank( [Column 1]) , [Column 1] , [Column 2] ))";
it works fine. and displays sum.
but if i use //formula 2 line  :
e.Layout.Bands[0].Summaries["Summary"].Formula = "sum(if([Column 1] > [Column 2], [Column 1] , [Column 2] ))";
it says : value# incorrect type of argument or operand.
can 't i use column comparision in formula ?
        private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
            e.Layout.Bands[0].Summaries.Add("Summary", Infragistics.Win.UltraWinGrid.SummaryType.Formula, this.ultraGrid1.DisplayLayout.Bands[0].Columns["Column 1"], Infragistics.Win.UltraWinGrid.SummaryPosition.UseSummaryPositionColumn);
            //formula1 e.Layout.Bands[0].Summaries["Summary"].Formula = "sum(if(isblank( [Column 1]) , [Column 1] , [Column 2] ))";
            //formula2 e.Layout.Bands[0].Summaries["Summary"].Formula = "sum(if([Column 1] > [Column 2], [Column 1] , [Column 2] ))";
            e.Layout.Bands[0].Summaries["Summary"].DisplayFormat = "Sum= {0}";
