255
Performance issue when binding to DataTable
I have run into a strange performance issue(and strange solution) when binding to a data tabe. I can't find the answer in this thread (http://forums.infragistics.com/forums/t/15306.aspx) but maybe you would know what is happening. It appears that binding gets exponentially slower the more columns are grouped at the top of the grid.
A few starting points:
-I'm not overriding any painting of the grid
-I have some column value lists, but they are not causing any exceptions to be thrown
-I'm not using a recursive data source. I'm only bind to one data table with no relations. Only one band.
-I'm using  a binding source
-I'm using .NET 2.0 and UltraGrid 7.3.1043
-I have ZERO events attached to the grid. So I'm not even running any code outside the grid itself.
The code is very simple:
BindingSource bindingSource = new BindingSource(dataTable, null);
GridSummary.DataSource = bindingSource;
The datatable in this example contains less than 500 rows. When I execute this code with no groupings I get a normal binding performance(I.e. less than a second). With one grouping(on a datetime field with mask) it takes about 3 seconds. Add another grouping(column with value list) it takes about 15 seconds. Add another grouping(another datetime) and it jumps to over a minute or longer.I'm mentioning what types of columns the groupings are, but it doesn't seem to matter in my testing. If I break while it is locked up at this point. It breaks on the one line:
The full minute is being used on this one line. I can find no code of my own actually executing during this minute.  Strangely enough, if I just manually remove all three groupings(on the screen), re-bind, and then put them back, it takes much less time then re-binding with the groupings(about 10 seconds).
Now I have found a solution, but I'm not sure why it is needed:
I changed the above binding code to look like:
if (m_BoundDataTable != null)
{//if we're already bound to something
    //clear data source without resetting the appearance
    BindingSource emptyBindingSource = new BindingSource(m_BoundDataTable.Clone(), null);
    GridSummary.DataSource = emptyBindingSource;
m_BoundDataTable = dataTable;
Now with this code everything works very quickly(I.e. less than a second), regardless of how many columns I have grouped
So after this long post...my question is: Is this a bug? Or is there something I'm doing wrong?
Even if you don't know why it is happening I would imagine this might solve some other peoples issues in this thread. I imagine it is fairly common to have groupings set up when binding to a datasource. I have not tested if having multiple bands might also cause this issue...
Thanks!
