85
building the Infragistics2.Win.UltraWinSchedule solution
If I load the source code and try to build the Infragistics2.Win.UltraWinSchedule solution I get the following error Error
 The type or namespace name 'UltraApplicationSettingsBase' could not be found (are you missing a using directive or an assembly reference?) C:\views\infragistics\UltraWinSchedule\UltraCalendarInfo.cs 9499 55 Infragistics2.Win.UltraWinSchedule
can you tell me where to reference the UltraApplicationSettingBase at or how to fix this problem
  • 220
    the ultraapllicationssettingsbase.cs is located in the common\infragistics.win project so try using that and see if it solves your problem.
