I have a bar chart where the label text can be very long. Word wrapping this not satisfactory as a previous post indicated, so I have to clip the text. I'd like tooltips for the labels to show the complete label text, while keeping the tooltips on the bars showing the actual data value.
My reading here suggests that the chart control itself can't do multiple tooltip values??
Can I use the UltraWinToolTip control for this? This means I need a method which will identify the chart primitive under the mouse at any time (say within a mouseMove event) - how do I do this?
related thread
http://community.infragistics.com/forums/p/30045/165536.aspx#165536
What version of the chart are you using? Do you see FillSceneGraph event on the chart control? What kind of intormation were you looking to display in the tooltip?
Hai
I dint see these two events in ultrawebchart. How can I get this?Can you give all sample code to get tooltip on all the X,Y axis labels(i.e. the points on the axis)?
Sridhar
Looks like there's no way to tell x axis labels from y axis labels, although, I believe that in the past they had different Path settings. Not sure why this changed, but it's something we'll have to look into. Typically y axis labels would have their Path set to "Border.Title.Grid.Y" and so on.
If you want to handle word wrapping yourself, you can, but it can be a little tricky. You can implement IRenderLabel. There are multiple examples of using IRenderLabel on these forums and in the NA help: http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/Chart_Customize_Labels_Using_the_IRenderLabel_Interface.html
You can gather information about the axis labels in FillSceneGraph, which will fire before IRenderLabel.ToString(). In IRenderLabel.ToString() method, you can insert new line characters or modify the text string in any way you choose. Hopefully, this will help you in creating a workaround for the auto-wrapping problem.
Thanks, that did the trick.
One final question. In my horizontal bar chart - its only the Y axis labels I want the tooltips for. I can easily distinguish betwen the two in the DataitemOver event because the X axis label text has a "%" in the text - but is there a more general way to determine this - I couldnt' see one from a cursory examination of the objects exposed in debug?
In reply to an earlier posting about isng the newLine character - these labels are drawn from user definied categories, and aside from a max length on the field itself I have no control over how long a description is entered (the longer ones work fine in printed reports and on grids or combo pick lists), nor can I arbitraily insert newline chars. IAC, the wordwrapping problem is how the chart control currently draws them (incorrectly).
