320
Win Grid Row Style
I have created a InitializeRow method below. I use it to style rows in a grid based on the strings contained within the selected row. This works fine but the style is not applied if the row is highlighted, ibstead the original isl style is applied. Basically what i want to know is can i apply a style  like "Me.gridTillItems.DisplayLayout.Override.ActiveRowAppearance = VoidStyle" but just to the selected row using the InitializeRowEventArgs object
Private Sub gridTillItems_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeRowEventArgs) Handles gridTillItems.InitializeRow
If e.Row.Cells("ItemName").Value.ToString.ToUpper.Contains("VOID") Then
             Dim VoidStyle As Infragistics.Win.Appearance = New Infragistics.Win.Appearance
            With VoidStyle
                .ForeColor = Color.Black
                .FontData.SizeInPoints = 10
                .FontData.Strikeout = DefaultableBoolean.True
            End With
            e.Row.Appearance = VoidStyle
End If
End Sub
