I would like to add a line on the X-axis of a 3D chart.
I currently have it placing the line in the middle of the chart.
How do I place the line where the value of X-axis is equal to "04/20/2009" (today's date).
The values in the X-axis are strings and not dates.
private void DeptChart_FillSceneGraph(object sender, Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs e)
ILayer chartLayer = e.ChartCore.GetChartLayer();
if (chartLayer != null)
Rectangle bounds = chartLayer.OuterBound;
Line line = new Line(new Point(bounds.Width / 2, bounds.Bottom), new Point(bounds.Width / 2, bounds.Top));
line.PE.Stroke = Color.Red;
e.SceneGraph.Add(line);
Sorry, I didn't see that you are looking for 3D chart.
There is no standard way that you can add a line in 3D chart. If you want to add custom elements in the chart you need to use 2D charts.
I could not get this to work. I am using Infragistics 9.1 with chart type : ColumnChart3D
The value of xLoc is being set at -2147483648 . (the lowest possible int value)
It looks as if all the X-axis data is default or set to 0. I checked Y-axis and looks the same.
If I change chart type to 2D it works great! Is it because the chart type is 3D?
Any thoughts?
In your case you need to know the index of this label in your data. You can try using:
private void ultraChart1_FillSceneGraph(object sender, Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs e)
IAdvanceAxis axisX = e.Grid["X"] as IAdvanceAxis;
int xIndex = 10; // the index of today's label
int xLoc = (int)axisX.Map(xIndex);
Line line = new Line(new Point(xLoc, bounds.Bottom), new Point(xLoc, bounds.Top));
