40
Unable to set UltraComboEditor in UltraGrid in version 9.1
Hi all,
I have UltraComboEditors set as the EditorControl to some UltraGrids, in the previous version (8.3) this worked fine. I just upgraded to 9.1 and it doesn't work...I get no Exception, I just like like nothing was set as the EditorControl, I only see the key.
Does anyone experience the same problem upgrading to version 9.1. The reason I am using UltraComboEditor is that I share the same instance of the UltraComboEditor through multiple UltraGrids.
Thanks in advance
Eric
  • 9190
    Suggested Answer
    I will be happy to assist you with this issue.
    Have you tried downloading to latest service release to see if this takes care of this issue?
    Please use the instructions in the following forum post to download and install the latest service release:
    http://blogs.infragistics.com/forums/t/29398.aspx
    Please let me know if you continue to receive this behavior even though you performed the suggestion I provided.
