270
Setting Order Of Summary Rows and Setting Caption
in _InitializeLayout(object sender, InitializeLayoutEventArgs e) event, i am manually adding 2 summary rows.
here is the code for this operation:
SummaryPosition usp = SummaryPosition.UseSummaryPositionColumn;
SummaryDisplayAreas s = SummaryDisplayAreas.BottomFixed;
sum_C_Line1= e.Layout.Bands[0].Summaries.Add("X_TOTAL1", SummaryType.Custom, new IMSCC(),  e.Layout.Bands[0].Columns["Column1"], usp, e.Layout.Bands[0].Columns["Column1"]);
sum_C_Line1.SummaryDisplayArea = s;
sum_C_Line2= e.Layout.Bands[0].Summaries.Add("X2_TOTAL1", SummaryType.Custom, new IMSCC(),  e.Layout.Bands[0].Columns["Column1"], usp, e.Layout.Bands[0].Columns["Column1"]);
sum_C_Line2.SummaryDisplayArea = s;
My questions are :
1- How can i change order of that summary rows ? I want summary row 1 to display over summary row 2.
2- How can i write some explanations on cells left of that summary columns on summary rows ?
(Please see attached picture for better understanding. )
  • 270
    Verified Answer
    Nevermind. I've solved it.
    Row display order is row adding order and
    for setting text on left side i 've used IUIElementCreationFilter and Custom Formula. I 've put a fake formula to the left column and set it 's width as 3 column's total width.
    see downloadable sample for more help.
