230
AppStyle Template - Grid Alternate Appearance
I may not be able to do what I'm trying to accomplish...but here's the issue:
I started a new AppStyle by utilizing the "Nautilus.isl" as the beginning template. I like the look and feel overall and "tweaked" it ever so slightly until I got the desired results. One feature I'd like to have on my Grid is an alternating row color...which when adding a grid without styling is easier using the override on the RowAlternateAppearance property. But AppStyle appears to be an image - in my opinion - that circumvents code I've added to set the alternate color on a grid's band.
Now...if I start with a blank Style Library - with or without themes - it works great. I can set the Alternate Item properties and see the results in the AppStyle designer. However, if I start with a template to use as my base - the best I can achieve is an outline on the row - which is why I assume an image is sitting on top of the cells. Here's an example with the Alternate Item Background color set to red - to standout - and the results:
Is there a way to get the background color I want to fill the cells across the row, or is starting with a template as my base design simply the wrong approach if I want to do this?
