I'm using .NET Advantage winforms v7.1
I have created a ribbon control, and several button tools on the menu(the circular shaped button), I have also set a large image on most of these buttontools during design time.
Sometimes when I run my form, the images do not appear, but sometimes they do, is this a bug?
I guess that since the button tool property's width and height properties are read only the large images can't fit.
Try setting them from the appearanceSmall property. Here is the code you can use:
buttonTool.SharedProps.AppearancesSmall.Appearance.Image =
new Bitmap(@"C:\Users\PMonov\Desktop\Win Cases\Ribbon\Ribbon\cat.jpg");
Sincerely,
Petar Monov
Developer Support Engineer,
Infragistics, Inc
