85
wingrid and field names..
I have a wingrid that has a datasource being set to it.
the field names of the grid are the same as in my MS SQL database.
however when I switch to a oracle database, the fieldnames are all in caps.
I am option compare text on, everywhere.
I am using vs2008 and  ultragrid ver 8.2.20082.1000
what is happening is all the field names are showing in the grid. not the ones I setup but what is in the dataset.  Is there some compare option in the grid that I am missing. It should be case-insensitive.
