I am using the ultraListView and adding some UltraListViewitem in it. While adding the item I am specifying the key(A1) for that item and it is working fine.
But when I am trying to add the 2nd item with the key(a1), it is thowing the exception. I think this exception is coming, because the UltraListViewItem keys are not case sensitive.
Is there any way to make it caseSensitive, so that it will allow me to add 2 items with the key(a1 and A1)?
Santosh.
No, the control does not support case-sensitive item keys; I don't believe any of the Infragistics collections do. If you like you can submit a feature request for this functionality.
