I have a wingrid that contains 2 types of data:
1. Status data that is automatically refreshed on a regular basis and is not editable by the user.
2. Configuration data that can be manually updated by the user.
I have placed an AfterCellUpdate event handler on the grid to capture when the user modifiies a field so that I can change the forecolor and flag the update.
However, when the auto-refresh occurs and I update the cells in the status columns programatically, the event handler captures the update and executes. I do not need to flag these changes, so I currently have logic in the event handler that looks for very specific columns. If the column being updated is not one of the config columns, I skip the code (do nothing).
I'd rather not have the even handler fire over and over agian as the refresh updates all of the status fields, so I was wondering if there was a way to set an event handler for a specific column instead of the entire grid. I tried suspending the event handler which worked, but caused problems, because, during an autorefresh, the user could still be making changes to the config data and I still want the handler to caprutre these.
Any thoughts would be greatly appreciated.
Thanks so much,
Steve
Hi Steve,
No, there are no events on the column. You would have to use AfterCellUpdate or CellChange and use a swtich (or Select) statement to bail out if it's not a column you need to process.
