I'm using the bellow code to insert a value list / drop down list inside a grid column:
ValueList vl = new ValueList(); vl.ValueListItems.Add("is"); vl.ValueListItems.Add("is not"); queryGrid.DisplayLayout.Bands[0].Columns["Logical Operator"].ValueList = vl;
My thing is that when the user selects one of the items in the grid it is also able to modify the text inside the relevant cell.
I don't want the user to be able to do so - i mean that the user will ONLY be able to set one of the suggested values given by the drop down list and will not be able to manually change the text inside the cell.
I have tried the following with no sucesses:
1. queryGrid.DisplayLayout.Bands[0].Columns["Logical Operator"].CellActivation = Activation.NoEdit;
2. queryGrid.DisplayLayout.Bands[0].Columns["Logical Operator"].CellClickAction = CellClickAction.Edit;
3. queryGrid.DisplayLayout.Bands[0].Columns["Logical Operator"].CellClickAction = CellClickAction.CellSelect;
Can you guys pls help?
THANX THANX!
-Gili
queryGrid.DisplayLayout.Bands[0].Columns["Logical Operator"].Style = DropDownList
I found the answer - just need to set the DropDownStyle to DropDownList.
Thanx anyway!!!
