570
DetectUrls for UltraFormattedTextEditor
I would like to swap out a RichTextBox in favor of the UltraFormattedTextEditor, but I am having a problem with getting links to show up.  The control will be used as a log viewer which will not be editable.  The logs which it will display will contain URLs as well as plain text.  The in box RichTextBox has the DetectUrls property which correctly auto identifies the URLs and formats them accordingly (underlined with blue forecolor).  I cannot seem to get this same functionality out of the UltraFormattedTextEditor.  I have tried working with the TreatValueAs property, but that doesn't seem to do anything.  I have tried the sample application "Ribbon With FormattedEditor".  That sample does show how to insert links into the control while in edit mode, but I have log files which need to be viewed in the control and have their URLs auto detected.  The sample's use of the TreatValueAs property also does not seem to do anything.  I am using version 2008.3 with the latest hotfix.
Any advice or help on this issue is greatly appreciated.
Justin
