I've added 24x24 images to the group headers of my explorerbar but they seem all squeezed into the left corner.
I would like to indent a few pixels on the left and then add some padding at the top and botton to give the images and text a bit of breathing space.
Could you please let me know how I can achieve this.
Many thanks
Abz
Thanks for that will give it a try.
There is no publicly exposed way to change the padding. One way to hack aorund this is to make your image size (for example) 24 x 28, then create new bitmaps out of the old ones that have 2 rows of transparent pixels on the top and bottom. The images will look the same, but the control will make the header 4 pixels larger since it thinks the image is 28 pixels in height.
