a few users of one of our customers currently experience the following issue when our program calls Infragistics.Win.UltraWinGrid.UltraGridLayout.LoadFromXml(Stream stream, PropertyCategories propertyCategories).
The stream is a memory stream and propertyCategories is set to PropertyCategories.All.
This results in a System.Reflection.TargetInvocationException.
The strange thing about this is, that no matter the source of the XML (in this case it is actually created in memory and loaded from anywhere) this fails. I have compared the XML with the XML on a machine where it worked and did not find any significant differences.
This issue on comes up on very few specific computers and not anywhere else.
We have checked the GAC and the folder our software has been deployed in and there are no anomalies either.
The users culture is US English.
Has anybody else experienced a similar error?
Here is the call stack
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at Infragistics.Win.UltraWinGrid.SortedColumnsCollection..ctor(SerializationInfo info, StreamingContext context)
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle._SerializationInvoke(Object target, SignatureStruct& declaringTypeSig, SerializationInfo info, StreamingContext context)
at System.RuntimeMethodHandle.SerializationInvoke(Object target, SignatureStruct declaringTypeSig, SerializationInfo info, StreamingContext context)
at System.Reflection.RuntimeConstructorInfo.SerializationInvoke(Object target, SerializationInfo info, StreamingContext context)
at System.Runtime.Serialization.ObjectManager.CompleteISerializableObject(Object obj, SerializationInfo info, StreamingContext context)
at System.Runtime.Serialization.ObjectManager.FixupSpecialObject(ObjectHolder holder)
at System.Runtime.Serialization.ObjectManager.DoFixups()
at System.Runtime.Serialization.Formatters.Soap.ObjectReader.Deserialize(HeaderHandler handler, ISerParser serParser)
at System.Runtime.Serialization.Formatters.Soap.SoapFormatter.Deserialize(Stream serializationStream, HeaderHandler handler)
at System.Runtime.Serialization.Formatters.Soap.SoapFormatter.Deserialize(Stream serializationStream)
at Infragistics.Win.UltraWinGrid.UltraGridLayout.LoadHelper(Stream stream, PropertyCategories propertyCategories, IFormatter formatter)
at Infragistics.Win.UltraWinGrid.UltraGridLayout.LoadFromXml(Stream stream, PropertyCategories propertyCategories)
Best regards
Sebastian PeschtiesLogimatic Germany GmbH
Hi Mike,
Thanks for your help.
For now we are looking for some other options to restore the layout.
Rooma
Well, if you can post a sample that demonstrates that, I would be happy to take a look at it. But without a sample, I'm afraid I have no idea why it's not working. Maybe your database is somehow altering the text for some reason.
Yes, I replaced my code with code given by you.
And still getting same exception.
Are you getting the same exception?
Are you sure you are not using the encoder any more?
Thanks for reply.
I tried using streamReader/Writer but it still does'n work. :(
