I have to fill a given Excel-File. But when I try to load this file I get then following error message:
Formulars cannot be set on a cell directly, use the ApplyFormula method or one of the ApplyTo methods of the formual instance instead
I have not idea what this means or where I can find these methods?
Is there another way to open and fill an Excel-File?
Thanks for your help!
I believe this bug was reported and fixed. You can contact the support group and reference issue BR27421 to get the hotfix containing the fix: http://ko.infragistics.com/gethelp. If the bug still exists, I would recommend submitting it.
