560
Hierarchical Grid to create a BOM like structure
Hi Infragistics-Team,
I'm trying to figure out how to create a BOM-like structure within the UltraGrid:
Let's assume I have parts, parts can contain another parts and all have the same properties (fields). We have a table structure like this:
Table PartStructure:
Part
ParentPart (can be null to set the root level)
Table PartDetail:
Part
Description
I've seen I have to "flat" these structure to two tables within one dataset to build a hierarchical grid:
Table Root:
Part
ParentPart
Description
Table Child:
Part
ParentPart
Description
These two tables are linked with 2 Relations:
ChildTableToRootTable (ParentPart -> Part)
ChildTableToChildTable (ParentPart -> Part)
This create multiple levels of Bands within my UltraGid:
Why is this? I simply want that every row looks the same.
Why does it create 7 Bands. Does this mean I can only go 7 levels deep?
The grid itsself is working, but I have problems to allow childs within childs (they also show up within the root):
Maybe my approach is wrong and maybe I need only one table referencing itsself. But then I must find a solution to hide the rows on the root-level when they have no ParentPart.
Thank you very much for your thoughts,
Frank!
