660
UltraTree + OutlookExpress Style + Columns = bad cursor navigation
i need a simple way to have a tree of data that could be edited by the user. Each node (on each level of the tree) has 3 columns with data. Just like this:
description ------ Additional text ---------- yes/no
+----- description of node2 ---------- add.text node2 ----------- yes/no
.............+--------- desc. of node 2.1 ---------- addtext node 2.1----------- yes/no
+----- description of node3 ---------- add.text node2 ----------- yes/no
+----- description of node4 ---------- add.text node2 ----------- yes/no
Just like a 3 column-grid with hierarchical data.
Now, this works with the UltraTree + a ColumSet. To have the Header just once i can use the OutlookExpress style.
This way i'm adding nodes and subnodes and it looks just fine.
BUT:
now if you select the first node you cannot move down to the next node with CursorDown. It seems, that now Cursor Up/Down is jumping only to sibling nodes (nodes at the same level). This Tree doesn't behave like a tree anymore!
I can see the Newsreader Example. Here it works like expected but: This example uses a dataset (maybe it works because of that?) and it doesn't allow editing of the cell-data (mabe it works because of that?)
Question:
How can i build a Tree with Columns and hierarchical data while at the same time let it behave like a tree? Cursor up/down should move thru all expanded Nodes on all levels. Mabe Cursor left/right should collapse/expand the nodes.
But i need to edit the data in the cells - so maybe left/right is blocked for moving thru the cells (but it would be nice to change that for example to ENTER or TAB for special cases)
Thanks a lot
