I'd like to know if is it possible to apply Custom GlyphInfo for UltraCheckEditor in AppStylist. I'd like to change CheckBoxes with my own CheckBoxes (images) ?
Thanks a lot
You have to use the latest version of AppStylist in order to be able to set properties that were added in later versions.
If you are having a problem with AppStylist in the later versions, then you will need to get that resolved. I recommend that you contact Infragistics Developer Support to get assistance in getting AppStylist working.
Submit an incident to Infragistics Developer Support
Thanks a lot for your answer. In fact, I've the last version of Infragistics 9.1 with last HotFix.
If the property is not showing up, you must be using an older version of NetAdvantage from before the GlyphInfo functionality was added. The GlyphInfo replaced the GlyphStyle property.
Thanks for your answer. I don't 've CheckBoxGlyphInfo property. For UltraCheckEditor component role I've just only 2 properties :
I don't 've Custom value for the property GlypgStyle. Indeed, I know change the property when I set a UltraCheckEditor on a classical form but not defined in AppStyling.
Yes.
Go to the editors canvas, mouse over the UltraCheckEditor and press the letter C on your keyboard. That will take you to the UltraCheckEditor component role and you will see the properties listed at the bottom. One of them is CheckBoxGlyphInfo.
