I have a grid with a column that is taking user numeric input. A selection the user makes from a drop down list controls how that input is formatted. Currently, their two options are "Amount" and "Percent". If they select amount I want the current active cell to have regular number currency formatting as if I were to set the whole column like this:
myUltraGrid.DisplayLayout.Bands[0].Columns["AGV_AMOUNT"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.Currency;
If they select percent I want the current active cell to have formatting as if I were to set the whole column like this:
agUltraGridGuarantors.DisplayLayout.Bands[0].Columns["AGV_AMOUNT"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.IntegerNonNegative;
Is there a way to do this?
You are on the right track, just do it on cell level rather than column level. You can either place your code in Initialize row and then force the row to initialize when the entry type is changed (myUltraGrid.ActiveRow.Refresh(UltraWinGrid.RefreshRow.FireInitializeRow)) , or have an internal method called on InitializeRow and when the entry type is changed.
The example below is vb, but it should be easy to change this to C#:
Private Sub myUltraGrid_InitializeLayout(ByVal sender As System.Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles myUltraGrid.InitializeLayout Dim valList As New Infragistics.Win.ValueList valList.ValueListItems.Add("Amount") valList.ValueListItems.Add("Percent") e.Layout.Bands(0).Columns("EntryType").ValueList = valList End Sub
Private Sub myUltraGrid_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeRowEventArgs) Handles myUltraGrid.InitializeRow SetCellStyle(e.Row) End Sub
Private Sub myUltraGrid_CellChange(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.CellEventArgs) Handles myUltraGrid.CellChange If e.Cell.Column.Key = "EntryType" Then SetCellStyle(e.Cell.Row) End If End Sub
Private Sub SetCellStyle(ByVal row As UltraWinGrid.UltraGridRow) If row.Cells("EntryType").Value = "Amount" Then row.Cells("AGV_AMOUNT").Style = UltraWinGrid.ColumnStyle.Currency Else row.Cells("AGV_AMOUNT").Style = UltraWinGrid.ColumnStyle.IntegerNonNegative End If End Sub
Trausti
